C
Chuck-75
I just completed a rear suspension rebuild. I installed a new fiberglass rear spring,(i think its rated at 330Lbs). well after getting the car back on its wheels the rear is about 3-4 Inchs higher then it was originally?.
Question does it take time to settle?. or do I now have to get longer spring bolts?(to adjust ride height?). I didnt know that the fiberglass spring would set the ride height higher?.
I did use new rubber mounts for the spring bolts, every thing else is ureathaine. Im using new bilstien shocks (I dont think these would raise the rear?). Ive added a new rear sway bar where there was none before. also new T-arm ureathaine and had the diff rebuilt,along with the T-arms bearings. .and new Spicer U-joints. .
tks all
tks all
