I was thinking about possible solutions to power a heated O2 sensor and thought I might ask for some suggestions. Basically it needs to be an ignition source.
I have a heated 4 wire o2 out of a last generation Buick Roadmaster. Works great! Make sure you have no air leaks. I tapped into the windshield wiper motor switch. There is a hot wire that comes on when the ignition is turned on.
Do you have a heated o2 installed now? Your sig says you do.
