VetteVirgin
Since purchasing my 61 I've been trying to determine exactly what type of engine is sitting under the hood and whether or not it is appropriate. Notice I did NOT say "correct". This is a driver and I'm more concerned with reliability and performance. That said, it wouldn't hurt if the components used actually had a bit of Corvette DNA also!
The previous owner told me the engine was a 350 that he thought came from a 80's Camaro. My own research has me leaning towards a very different possibility and has already eliminated the 80's Camaro.
What I have found is the following:
Block: 3970010 casting CE241361 stamping which makes it a 72 replacment casting from the Flint plant.
Heads: 3917291 "camel humps" F13 8 which makes them 68 heads. I know these were used on 68 275 and 325hp 327s. I am not sure about their use on 350s in 68.
Manifold: 3872783 cast iron/Holley carb intake for 66-68 327s.
Carb: Edelbrock 1406
I have not gone so far as dropping the oil pan to check the crank casting, which would definitively answer the dispacement issue.
So my current best guess based upon the accumulated evidence is that the original 283 was most likely replaced with a 68 327 which later required a block replacement in 72. Since 350 and 327 blocks are virtually identical with only the crank determining displacement, the previous owner assumed it was a 350.
I believe heads, intakes and blocks with these casting numbers were all used at one time or another on Corvette SBs in the 60's and 70's.
Does my conclusion seem likely? And more importantly, is this engine appropriate for a Corvette?
Thanks!
DT
Thanks!
DT
