Phil
I just pulled out my driver's seat to get repaired and I was wondering if I could put the passanger seat in its place? Any thoughts?
Phil
Phil
The seat "frames" are really two separate components. Once you remove the seat bottom cushion, you will see the plastic seat frame. There are 4 bolts that hold this part to the seat base which is has the adjusting track. The plastic frame has the lever that adjusts the angle of the seat back and it is on the door side of the frame. So these pieces are not really interchangable. The seat backs should be interchangable from side to side. Remove the 4 bolts at the bottom of the seat back and the cable to the release lever at the top of the seat back.Phil said:c4cruiser,
Thanks for your response.
What about the seat frames? Are they interchangable?
Phil
