Mark Oliverio
I noticed in the owners manual that plug replacement isn't necessary till 100K. Your experience?
Mark Oliverio said:I noticed in the owners manual that plug replacement isn't necessary till 100K. Your experience?
Hib Halverson said:Saying that was GM's wishful thinking is an understatement.
What do I use?
Denso Iridium Power. In a LT4, I'd use the IT20
I've had my platinum tip plugs lose the little puck...
I have yet to see any GM high-performance engine have OE plugs that last 100,000 miles. Wose, yet, the early AC double-plats had defects which caused the bond between the platinum "puck" and the electrodes to fail. That is why, as posted earlier, plugs manufactured in the 92-95 period had problems with this. After 95, Delphi finally got to a point where it understood the bonding process and the AC double-plats are far more durable.
I'd say, if an engine in a Corvette that is driven as it was intended to be, goes 50,000 miles on a set of OE-type double-platinum plugs that'd be pretty good.
What do I use?
FX GS said:Hib, do you use the factory gap setting?
also, what do you think about the cut electrode trick?
