kevin-design
Well, I had my fingers crossed, but it just wouln't be fair to let me get a clutch repaired without any hangups...
So I bought the RAM clutch kit from Summit racing. (this one):
http://store.summitracing.com/partdetail.asp?part=RAM-98764
And hired a mechanic to switch it out. It took a week to get to my car, and the plan was that it would be done tonight (flywheel resurfaced). Well, I found out today that they can't resurface this particular flywheel for this particular vette. Apparently I need to buy a replacement flywheel.
I also found out that this wasn't the factory clutch as I'd believed ( have no record of a clutch repair). Anyway, so I found this out at like 5pm and made about 50 frantic phone calls, first in town, then somewhat out of town- then to major cities, then to performance catalogs (summit, jegs, etc.) and finally (as places started to close up) to the west coast where I was hoping they could still make an overnight shipment.
Unbelieveably-No luck. Am I the only guy in the whole country that needs a f#$&# flywheel?!??!?
The only thing I was able to find was an aluminum flywheel (here: http://www.madvet.com/shop?store=3.&frame=3186&part=611593 )
from a place in Effingham- 1.5hrs south of here. I have received mixed opinions on whether or not this will work with the ram clutch that I have. In either case, it sounds like due to the lack of springs that the stock flywheel (apparently) has its engagement would be rough, jerky, and noisy if it worked at all. One guy told me that they replace clutces with a centerforce kit that includes the flywheel. This would be a dual friction kit for like $750 or something. Everyone I ask seems to have a different opinion or recommendation for how to handle this situation. I was hoping to have this done today or tomorrow so that I could drive it home to Chicago this weekend. I guess I should face reality and re-insure my z28 or take the vmax or something. Probably no sense in rushing a job like this with mismatched parts. Still, since my car is in pieces and taking up a bay at the garage I want to handle this ASAP. Anyone who can help me make the right choice, please post here.
many thanks!
-Kevin
Questions:
What's a Dual-Friction ('dual mass'?) clutch? Is this strictly a reference to the coefficient of friction of materials used?
Should I consider an aluminum flywheel?
Will parts mentioned work together?
Should I return my RAM clutch and buy a complete kit (inc. FW)?
Who has this stuff IN STOCK!?
What do you call the integrated spring mechanism(s)?
Why is a factory flywheel (ala Napa or dealer) $1k+ (AND OOS)?
many thanks!
-Kevin
Questions:
