8
86redMed
Hi everybody,
when I bought my car (4 month ago), there was a little leak from the transmission. After a small cleaning, it appears that the transmission oil pan gasket was cracked.
Well, I've changed the filter and its seal, clean the oil pan and gasket surface and put a new gasket and it is still leaking !!
I have thighten the oil pan bolts at 96 in-lbs like it is said in Haynes manual. Is it the good torque ? Chilton says about 15 ft-lbs...
Does this transmission (late 1986 TH700R4) needs a sealant on the gasket ? Or is it another problem (oil pan deformation, another leaking point, transmission gasket surface deformation)?
I need your help and your precious advise guys !!!:cry
