- Thread starter
- #21
Paul
bolt-on KO's were what I was planning on.
studiog said:Barry, He doesn't have to replace the balancer to figure out if the timing mark is in the wrong place. And even if by some chance it was in the wrong place he could just put a new TDC mark on the balancer that is on there to verify he is correct before installing new parts.
BarryK said:Dave
that i don't know. he said after the timing numbers were off by so much he looked at the balancer and just told me it was the wrong one for that motor and therefore the reason everything must be off.
If it is the wrong one, can a new mark be made the same as if the correct one was on there but had slipped?
D*mn, this is why it's time I learned how to do this stuff myself - I have no clue when a mechanic tells me something if it's legit or if I'm getting BS'ed.![]()
That is EXACTLY what he told me last week. He said that while she is running pretty good now I'll be very happy about how she is running when he is finished.Vette66AirCoupe said:It should run just as good or better than when you gave it to him when he is done.
BarryK said:well, just picked up Baby from the mechanic. Overall she was in pretty good shape and now she seems to be running just fine
She needed an adjustment on the clutch - he said there was no or very, very little free play so he adjusted that. Replaced the old bad battery that kept dying and leaking acid all over the frame rail and battery box but he repainted the battery box and left the frame rail to do as I need to.
Turns out the alternator was fine but the regulator died so that was replaced which is a shame because I still had the original unit in there - oh well, after 40 years one more original part bit the dust and had to be replaced.
Now, the big to-do ever since I bought the car - the timing issue!
Turns out that he went over everything dealing with timing again and the harmonic balancer was NOT bad and had NOT slipped afterall - the timing was really that far off the way it had been set. He got everything reset properly and he said she is now timed at 34* as it's supposed to be and she is running nice and smooth. Idle is good now and she runs smooth and power and acceleration are all real nice.
(I still have my "appointment" with Lars in Sept on his NJ trip so we will see if he can maybe even tweak Baby a bit more with his magic)
I also had him adjust my valves (365hp solid lifter motor) as per JohnZ's method of doing it cold and while a few valaves were out by a few thousandths he said overall they had been adjusted pretty good already and they have a real nice "singing" sound to them.
Replaced the plugs with new R45's.
He checked ALL fluids and everything looked fine.
Of course, we changed the oil, filter and air cleaner and lubed all the grease fittings.
He checked EVERYTHING under the hood and under the car and said everything looked in excellent shape. He did have to torque down the intake manifold bolts as they were loose but other than that everything else looked real good.
So, now I can FINALLY enjoy Baby for the rest of the season without too much concern or worry.![]()
