playsdixie
85 vette battery dead after 5-6days....voltage loss at separated neg terminal at 3.84,,,,removing cts/clk fuse stops it.....check all 12 circuits per the fsm....no luck...bose relay is suspected but bose tech says if I disconnect rear two speakers, voltage loss should be reduced..no luck...now I dont think it's necessary to tear the dash apart to get at that relay...removed spare tire bulb /burnt..map lights don' work...all courtesy lites go off'/on correctly...nothing on at night....any ideas??? besides a battery switch????? did record .03 volts at the blue wire at the rear speaker.....with:ugh all off.....don't think thats significant but could be wrong...need a little help....
