sweible
I have had a battery drain for some time and have installed a cutoff switch to control it. It would be nice not to fix the problem so it's not a issue anymore. I connected a volt meter between the neg. post and cable then pulled all the fuses one at a time while watching the meter - no decrease in the amount of drain. I then disconected the six wire plug in the engine compartment above the starter in the evaporator case area. This in an attempt to determine if the drain was or is under the hood. No change. The amp draw is still at 2.7amps! Where do I go from here? How do you determine where to look if the problem isn't in a fused circut or under the hood in the starter or alternator? Oh, I also pulled the plugs on the relays in the pass. side rear hatch (where the jack is) with no change. Any advise would be GREATLY apperciated.
Thanks, Steve
Thanks, Steve
