caplack
New member
Schumacher tender
I just installed a Schumacher 1.5A tender and don't know if it is really working. The manual, and their technical adviser, say the same thing which is: "Green LED indicates Power ON @120VAC. When battery is fully charged the RED LED should go ON indicating a FULL charge and now in maintenance mode."
Every time I check, only the Green LED is ON and my DVM shows a 12.5Vdc charge in the battery.
In performing some bench testing, I attached a portable charger's output to the tender and the RED LED came on. This was at ~14Vdc.
Then while leaving the tender hooked up but not attached to an AC supply, I put a charger on the battery at 2A. It appears that this tender cycles at around 13Vdc. <13V RED LED off; >13.1V RED LED ON.
If this unit is working properly, shouldn't I sometimes sooner or later see the RED LED on, or is the drain on the battery (computers, memory, etc.) greater than the tender can replenish. Does not sound right to me.
Thanx.....caplack
Thanx.....caplack
Do the math.
