I have not owned my 93 for long and have been reading up on the various performance modifications for the LT1 and now realize the choices are limited.
For the money, what is the best modification that I can do to add HP? From what I see:
1.1.6 ratio rockers.
2.opening up the heads with some porting.
3. CIA? I am not sure on that one as a stand alone but it would possibly help if 1 and 2 are done
4. Exhaust
The "airfoil" looks like a waste to me but could help if all of the above are done. The coolant bypass makes sense in therory since it sort of cools the air in the intake (however I am skeptical). Larger TB's 52 or 56 mm may add power if only 1 and 2 are done.
As far as 3. The SLP and vortex systems look nice, but wouldnt it be the same thing if I cut a hole in the air cleaner cover? I mean the stock system is set up like a CAI already. The other thing that looks interesting is the big mouth air dam. If it works I could see the CAI (or cutting a hole) would work better since it looks like it pulls the cool air from under the car.
Any help is appreciated from some of you folks that have tried a few different things and I may be covering ground that has been covered several times.
4. Exhaust
