:O Wowwwww John! You really KNOW about corvettes man!
Im really impressed with that car, is fascinating... if you bridge the scanner connector, you can know if everything works fine, even a bulb! That car is really amazing... really amazing... and is maded by the normal people can do that kind of stuff....No Mercedes i had has that amazing things, so im really impressed with that car....
That car is really complicated like i know about several months ago, but now, i think is more complicated that i thought, thats AMAZING that loops that you are explaining me... im really impressed...
I really think that is the problem of my car, and now, in what wires i need to search to discover my problem? because i really want to fix my car :-( my new wiring i think it arrives in like 1 month, and i would be happy if i repair my car soon. And with your help, i think i can
Now, thats the MSD distributor Story:
When i bought the MSD distributor in USA, it arrived to my country in 3 days because i want it now and i payed 100$ only for the shipment DHL via. The total cost was 780$, complete distributor.
Well... when my beautiful distributor arrives to my home, i inmediately disarm my car, the water pump, and everything, and i put there my new distributor like in the distributor manual says, and everything is perfect, when i connect the MSD connector and the connector on the harness of my car, i see that CANT fit... connector of the wiring has 5 wires and the MSD only 4 and the connectors was tottally diferent... i sent an email to the seller and to a MSD, very upset because in the box says ``92 to 94 LT1 corvettes´´, well they send me that email:
David,
> You really need to solder the wires, if you butt connect them, you chance it
> getting loose. Once you cut the wire on the MSD, MSD will not warranty the
> distributor.
> All the wires are the same, pin to pin. The PIN locations are very small
> and are cast into the plastic connector. They are the same on the 4-pin
> connector as the 6-pin, so you should not be confused.
> Pin 1 on the MSD (brown/yellow wire) goes to Pin A (Blk/red wire) on harness
> Pin 2 on the MSD (brown/orange wire) goes to Pin B (purple/white wire) on
> harness
> Pin 3 on the MSD (red wire) goes to Pin C (yellow wire) on the harness
> Pin 4 on the MSD (red/black wire) goes to Pin D (black/pink wire) on the
> harness
> A PDF file is also e-mailed for reference.
I do exactly the same thing, i solder the wires, a perfect job. That is because ONLY THE 92 CORVETTE has a different connector on the DISTRIBUTOR, only the 92, look at that
in 93 the connector changed and if my car was 93 i do not will need to solder any wire.... only plug and play....
The MSD distributor has another vaacum lines, that i connected really well, i think was a good job. But, i think discovering the failure that i or the mechanic do something wrong and now the car has that failure, i will like to know why, and what, to fix it
Another thing: Without the memcal, the fans are ALL THE TIME activated, i pass the suich and they work, and works all the time, the 2 fans... so my car is really cool all the time. Sometimes the car throws a smell that my eyes dont like it.... my mechanic told me is ``raw gasoline´´ and only for 1 exhaust, the passengers side one.
Really thanks for everything John, now im waiting to know what i need to do or what wires check to start fixing my car!
Read this to know what i did and what i need to do, for the distributor... or my failure.
Another stuff of my car, sometimes the car sounds in the exhaust hard, like an explosion, like if the spark was too much or the gasoline blow up a little bit because the car is not good entonated, and that happens when i accelerate it several times at once.
Another question, if my MSD is not working good because i need another wire or 1 wire is broken, why the car starts? i think that will not work at all and the car will not have spark because the distributor is not working good, or the distributor can works parcially? Well im not a mechanic and i dont know anything about that, i did several jobs on my cars and i like flawless jobs, averything in his place, cleaned and good threated, and if i dont know how to disarm something, i think and i do my best to dont wreck anything... My mechanics dont, it disarms everything fast and sometimes broke a plastic and that things.. well, thats one of the reasons that i like to fix my car
Im here to listen you
the people who knows!
