topace
Hi guys
I have a 93 coupe, I recently change the spark plug wires and give a little bit care to the engine just removing dust (NO Water). I had it raise in jacks just to be able to access the wires more easy. The thing was I lower it and forgot a jack that was placed down, so you can imagine I hit the oil pan and make a tatoo in the oil pan at first I didn't think it damage any, I started it and let her run for a few minute, then a bleeding of oil came from the oil sensor level, as a maniatic freak I decide to remove the oil pan and install a new one. With a lot of effort I remove the oil pan and install a new gasket (beautiful gasket) a new pan, a new oil sensor level (a plastic one even do it was Delco), some new Oxigen sensor (I have the space), New Fuel Filter. I just re-assemble the parts no screws left over pour oil on it ready to hit the road, NOW she won't start. It crank but will not start, check every connection and she wont start, check for loose wire and she wont start:bash I have fuel pressure on the rail, fuel pump sounds, but no power on the injectors ( i have some tester for the injectors), so I decide to remove the coil ignition , buy a new one, buy a Ignition module, and she still wont start. No spark on any cable
The ECM was replaced about 3 Years ago
Should I assume the distributor died!
ad have to buy a new one?
Any thoughts are appreciate I'm starting to giving up
