B
BeaterShark
First, a little background:
Late last year, my brake pad caliper codder pin broke and I lost a brake pad. This ruined a rotor and caliper pistons on the driver's side front. I installed a new rotor and put in a o-ring caliper kit. This is when my problems began.
My brakes are pretty much fine as long as I drive straight or make left turns. I do admit that they are "softer" than I'd like, but there are no obvious problems. The brakes are not power assisted.
My problem comes in when I brake after I make a right turn. It makes no difference if I brake immediately after or 5 miles after I turn. Here is the best that I can describe in words what is happening. I lightly press the brake pedal and I feel resistance and the car will pull to the right. Then I increase the pressure on the pedal and the pedal gives a little and then the car tracks straight. I'm pretty sure that the "give" is the caliper pistons on the driver's front pushing the pads against the rotor, but this would mean that the pads are being forced away from the rotor.
I could understand this if it happened all of the time, but it ONLY happens after a right turn. It is 100% repeatable. My drive to work is about 12 miles and has 4 left turns and 4 right turns and the only times I had this problem is after the 4 right turns.
I have checked the bearings for play and it's within spec. I also have turned the wheel and checked that there is nothing out of the ordinary happening when the tires are turned. The brake line is fine and nothing appears to be intefering. Also, I cannot reproduce the problem when I'm not rolling.
I must also note that I did not bleed the rear brakes as I didn't touch them and the fluid level never changed in the master cylinder.
Anybody have any ideas?
