douglas foster
- Joined
- Aug 18, 2005
- Messages
- 226
- Location
- minnesota usa
- Corvette
- 1984 C4 Gold coupe, Z51, 4+3 manual, BBS rims,
Pulled cover off for spring, sat in vette, depressed clutch to start, peddle droped to floor with a bad feel. started car and clutch catches just off the floor. so bleed first, or replace master? any special info,except the 45 degree on the slave when bleeding the system. i just replaced this whole system last summer!! when bleeding last yr i really had a hard time bleeding. i though that you attach a line from bleeder to jar of breakfulid, pump peddle,open bleeder valve, peddle drops to floor,close valve, add fluid to master, repeat tilll air is not comming out into jar. what would happen, when bleeding the clutch peddle would get rock hard when pumping and not drop to floor when i opened bleeder valve. so i closed up system and it worked till now? did i screw up??
