BLEEDING BRAKES
  • Thread starter Thread starter LUCKY13
L
LUCKY13
Can anyone tell me if theres a device I can buy to pressurize the power brake master cylinder on my 65 to get all the air out of the brake system?
I've rebuilt/replaced all the components but I can tell that there's still air in the system.
Only ways I know of.....vacuum systems that suck on the bleeders, or have someone push the pedal down or gravity bleed
those are the ways I know of how to do it. Gravity bleed seems to work pretty good, just takes time, just don't let the MC run out of fluid.
I recently read about one that pushes fluid from teh caliper to the MC.. looking for the article... Sorry not at thand but I saw pics adn it had a how to article that went with it.
When I have yoru wounded
Charlie
Hey John,
What about the cap that screws onto my MC. Does that come with the kit or do I need to sacrifice one of my existing caps and modify it to attach to the bleeder unit?
Hey John,
As I recall, their #1105 GM adapter will work on the '65-'66 Corvette power master cylinder; the fluid inlet hole spacing in the adapter fits within the spacing of the reservoir openings.
I use a 6" C-clamp and a length of aluminum tubing to clamp the adapter to the master cylinder instead of the chain-and-wingnut arrangement they supply.
John,
I have this tool and the c clamp is a great idea
I have used the chain and wing nuts, it is clunky but does
work and I paid a lot more than 65 for it.
