S
SteveF
Last week the engine in my 1984 C4 let go while on the highway at 80 mph. Compression tests show about 50 lbs in each cylinder. Timing chain / gears are okay so I believe the problem is in the block. So here's my question. Does the corvette use a block that's specific to a vette or can an "ordinary" 350 block work? Will the heads, intake, ect work?
I got the car to drive & have fun with & don't enter it in shows, ect so I'm not concerned with the devaluation of the car that the use of a "non - corvette" part could cause. I would like to know if I need to find a corvette block / engine or can use a standard 350 block. I've even asked my local chevy garages & they're not sure.
I had driven the car about 70 -80 miles earlier in the day. Had just stopped for gas and while back on the highway for about 5 minutes the engine started to lose power & a loud rattling sound began. Engine then shut down. No loud "booms" , ect. Engine would turn over but not fire, even sounded like there was low or no compression when trying to restart.
Appreciate the help & thanks in advance :cry
otfl
