Corvette-Pilot
I finally took the plunge and started the gut out the Blose system. Man, what a bunch of surprises ! Anyway, I had ordered the Metra dash kit and wire harness adaptor. Brought the adaptor into work to solder it up to the Alpine HU harness no problem. Monday I got the Blose HU out and see the harness is different?? The Metra Haness that I used is 70-1858 . I suspect it is the general purpose harness.
I know there is an adaptor harness that lets you use parts of the Blose system and costs about 80 bucks. That isn't what I need.
But for now all I have to find is the Always ON 12v lead, Ignition lead, Illumination lead, power antenna lead wires. The rest will be run as new cabling. Anyone know which color wires at the factory harness will do the trick?
