Jack
- Joined
- Dec 27, 2000
- Messages
- 1,825
- Location
- Florence, SC (Timmonsville SC)
- Corvette
- 71 War Bonnet Yellow VERT 71 BH Blue CPE (SOLD)
Accel 8.8 mm 300+ Ferro-Spiral Race Wire
Edmond:
The larger wires are usually better ... but simply having 7 or 8 or 9 or 10 mm wires is no clear indication of how the wire's conductor is configured. What you want is a relatively low resistance core having spiral or helical conductor windings (you do not want a solid metal core ... nor do you want a graphite-only core). As far as outer diameter, go with at least 8 mm ... 8.5 & 8.8 mm are all you'd ever need. In simplest terms, the larger the outer diameter ... the more insulation (a good thing). Your local parts store should stock a good quality spiral core wire set for $40 -$75 ... depending on performance level. Taylor, MSD, Moroso, Jacobs, Accel ... they're all very good. I prefer the lifetime guarantee Accel spiral-core 8.8 mm 300+ Racewires (set numbers begin with a 7) ... comparable to the MSD 8.5. I like those particular Accels because they have a glossy black finish that is easy to clean and I don't care for neon colors anyway ... and they work quite well. Ask the counterman for a name brand spiral set ... at least 8 mm ... probably no more than 9 mm ... spend no more than $75. Expect to change out your looms too ... to a larger size.
JACK:gap
Edmond:
JACK:gap
