76okievette
I have read alot about bleeding and have all the tools, power bleeder, two people allset to go. Last issue, cleaning or pruging does this have to be done and if so what do you use? I assume that you drain out all the old fluid the pour in some pruging fluid and than drain it out then are you ready for the new fluid or is there another step. I am thinking about DOT 5 but may go with Dot 4 just not sure about the clean purge step. Help
