Peer81
Well, a very simple question.
When I put the key on acc the brake indicator light will not go on, when the engine is running the light will still no go on with or without the handbrake applied. Thing is, I checked the bulb and that is fine. I turned the cluster to see behind it. I check the left and right connector and on both the left and right connector is 12 volt, this should be correct when the engine is running without the handbrake applied but not in the acc. position... So I'm looking for a switch that will ground in the acc. position and send 12v if everything is save when the engine is running.
Btw. Yes I have the manuals but to be honest I'm to lazy to dig into them right now. Hope somebody can point me in a direction..
Greetings Peter
Greetings Peter
