Problem still as bad as ever. Not sure if this is related.......but I did have console apart a couple days ago (installing new carpet), and this problem just started after putting it all back together. I don't think that I pinched any wires, but I suppose its possible. So if you guys can think of this issue with this new info in mind, great.
Stallion, I did change out the flasher, no difference.
dman, no, i don't think that i got into the tail light bulbs.......
JohnZ, regarding turn signal switch, does that make sense to you with the new info about console removal? I did look at wiring diagram, can see brake swith 14 ga orange and white leads going to fuse panel, through flasher (Stallion's idea) then ultimately to turn signal. So how sure of the faulty turn signal idea are you? Is there a way to test this b4 going to the trouble to replace it? Note JrdnsEdu's comment.
JrdnsEdu, yes please can you email it to me?
THANKS GUYS:confused :eek :crazy
