M
mgms_1968
Does anyone know of a 7/8 bore master cylinder that will bolt up to a stock corvette mounting system?
The reason I ask is that I have a 1968 vette with manuel brakes. I just completed a major overhall of the brake ssytem. New calipers, rotors , lines from Vette Brakes.
I also replaced the master cylinder with a new one at the same time.
The car does not stop as hard as I would like so I called Vette brakes fro tech help.
They suggested that if I find a master cylinder with a 7/8 bore which will increase my brake presure by about 20-25 percent.
Hopefully I can find one that will bolt up with out and modifcations to the firewall.
