On my 1992 LT1 the brake pedal is hard to depress before starting. The vacuum is obviously leaking down as the car sits. My question is, Is there a check valve that could be going bad or do I have to replace the whole brake booster? Thanks, Tom
Brakes work fine once the car is running. I figured out where the check valve is...Duh! That is the first thing I suspect.
The check valve is the little plastic coupler that the vacuum line plugs into on the booster. You can get a new one at the HELPS counter at most auto part stores. Remove it and try to blow through it from the manifold side. It should not allow any passage in that direction.
