J
Johnnyfly41
Hey guys, new to this group, great info by the way. My 71 vette loses pedal without loss of fluid. I replaced the calipers twice, master cylinder twice with rebuilt units. I replaced the rotors, that seemed to help the most, drove all summer with less than ideal pedal, but I did not completely loose it. Flexible lines are newer, no leaks anywhere. I just bought a proportioning valve from a outfit out of Hudson IA. I will install that in the spring when I get the car back out.
I have seen posts regarding runout and such. I suspect this is the most likely culprit. I still never get what I feel is a real solid pedal, be it from manual bleed or vacuum or a combination.
Please feel free to lay some of your wisdom on me.
thank you,
John in NW Illinois
thank you,
John in NW Illinois
