jbonifas
Got a brake problem I hope someone can help me with. When I push on the brakes, I get a bad pull to the right. I replaced both calipers, (one was leaking), pads and turned the rotors. After a quick check, drive around, it was still pulling and the drivers side wheel was "really hot". Seems like the caliper stays engaged on the drivers side and when I put on the brakes, the passenger caliper engages and it pulls.
Is there are problem with the master cylinder? Brake hose? Line?
Any help would be appreciated. Thanks
