Todbo
Hi All,
In getting my 94 ready to visit Gordon Killebrew last Thursday (that's Atoka, TN - Cross Plains, TN and return) at about 1 mile after starting I noticed I had a slight drag from my brakes and slightly higher RPMs. Thinking that the hand brake was slightly engaged, I stopped and made several attempts to release the hand brake, however, such attempts only served to increase the brake drag. Being stopped on the side of a busy highway l drove another mile to a place where it was safe to get off the highway. At that time both of my rear brakes were smoking slightly. After attempting to release the brakes for about 20 minutes all of a sudden, I found that I had no-brake drag and normal RPMs, but with a slight reduction in brake pedal height. After driving about 5 miles the pedal returned to normal height and I decided to go on to Gordon's, and I completed the trip without any additional problems.
The 94 had been in storage since the 2017 Birthday Bash and after airing up the tires and spare I had raised the brake handle slightly the day before when cleaning the interior, and although I had not gotten a brake warning light that morning, I continued to assume the brake drag was hand brake related, and thus Gordon and I did not focus on the brake matter. However, coming back into Nashville on I-65 I again found I was getting a slight brake drag, and that my RPMs were higher than normal. Stopping in Nashville, I removed the cover on the brake handle and again went though several attempts to free the brakes. After about 20 minutes I again found that I had no brake drag. Getting back on I-40 at about 1 mile East of Centerville TN I suddenly found I had a significant brake drag and high RPMs. Limping into the LOVE'S station off the interstate the motor would barely pull the car in second and both of the front brakes were smoking. At that point it was obvious there was more than hand brake drag. At this point I still had a full break pedal, however, after letting the Vette set about 30 minutes without any attempts to disengage the hand brake, I found the foot brake pedal going to the floor, and zero brake drag, and normal hand brake function. Hand brake function remained normal the next day when I loaded the car on my trailer to tow it back to Atoka, thus is this a master/wheel cylinder, or ABS, or other problem?
FYI, I checked the ABS fault code after the drag disappeared and found all dashes, so unless the fault disappears when the drag disappears, perhaps the ABS can be ruled
out, eh. In the last brake drag(at Centerville), both front wheels apparently got hot enough to lose the center caps. Caps in the rear wheels and all vinyl lug nut caps are OK. Any ideas as to how much heat the tire sensors can endure?
Thanks for your consideration.
Now for the problem at hand...That’s a puzzler. What’s happening doesn’t make much sense to me....my first thoughts were possibly just a stuck hand brake shoes....but I think you have eliminated that possibility. So my next thought was caliper pistons not releasing...I’ve had that happen on a pickup I had, but those just grabbed and didn’t release at all. Which
