Question: BUILD SHEET PRODUCTION DATE
  • Thread starter Thread starter kenmack
K
kenmack
Where on the build sheet is the production date ?
There is a date at about the centre of the sheet but I suspect it is my order date 22/05/92.Too early for a 93 ????
There is also a time 6:57 right below the date.
Can someone possibly put a copy of a "complete build sheet up,I lost the top right hand corner taking it out of the front crossmember.
Yes I know I can get one from the Corvette Museum:upthumbs
P.S. My partial date on door is 09/92
I don't have a picture of mine, but the only date on mine is at the top middle-right, mine says 09/20/93 at the extreme top-right is the time and the box below it says "EXPORT" with nothing in it.
I always assumed that the date was the "start date" of the vehicle starting down the production line.
When I visited the Assembly plant they said it took about 8 days to build a single car (that is IIRC :chuckle).
Probably missing
That pretty much confirms that the piece I want is still stuck in the front x'member.
I guess I should break down and order one!!
Thanks for the info:beer
My car was ordered on 1/31/1993 the production date and time stamp which is in the loaction which you seem to be missing is 2/16/1993, 5:52:14. Delivery was 3/17/1993.
tcxd40
BUILD DATE / TIME
Based on a little more research it seems my build date IS on the build sheet.:)
It is the top row of boxes(box #6)and it reads DATE: 92/225
TIME: 06:57
Apparently this stands for the 225th day of 1992 which works out to
Aug 13th of 1992.(Finish BUILD DATE)?:confused
This correlates nicely with the door jam partial date of 09/92.
(I think this is a FINAL INSPECTION or possibly a SHIPPED DATE from the factory yard).;shrug
Any further info is appreciated. Thanks in advance
TIME: 06:57
Interesting, box 6 on mine is the code for the rear spring.;shrug
tcxd40
Pic of my sheet if it uploaded?
tcxd40
Wow
tcxd40
Thanks for you time and trouble.Mycamera downloads aren't working right now or I'd post my sheet from the front frame x-member.
Yours is totally different from mine/ formatting/ everything :W
Don't think I've seen one like the one you posted.Maybe an in-house assembly plant order ??????
kenmack,
I have three sheets just like the one pictured. All from 1993 corvettes. Although none were the 40th anniversary edition.
tcxd40
download picture
As soon as I get my computer download link fixed I will post a picture of my buildsheet from front x-member.Thanks again.:upthumbs
On my 1990 ZR-1 (#566) build sheet there are two date references:
SCHED. NO. DATE 0105917
DATE: 89/297
TIME: 12:37
The second number sequence would be 89 for 1989 and 297 for the 297th day of the year which would be 10/24/89...yet on the lower inside hood is a grease pencil marking 10 27 89A (which according to NCRS types is the build completion date). Assume build sheet was issued (thus start of production) on 10/24/89 and car finished production 10/27/89.
The ZR-1 was recorded into dealer stock on 11/20/89 (that date and dealer stock number also in grease pencil on the upper underside of hood) and sold 11/21/89 (have the original bill of sale)... so it took about 25 days to leave BG and arrive to the St. Petersburg FLA dealership (Maher Chevrolet)
Michael
Attached see build sheet from tank
double click twice to enlarge
See top centre build date92/225:beer
anyone with a EARLY 1984 and they have a build sheet for it
TIME: 06:57
my build sheet has almost no information on the top row.....
who has their 1984's Build sheet ..... What does it say in boxes #02 to #7A ( mine are all empty )
Any help will work.....Door Jam Label says 02/83
and the engine mounted tag says ( E 02G 100521)
.....Box #01 is the JOB SEQUENCE NUMBER (0012909)
.....Box #08 has this Number in it twice (001290)
.....Box #07 and 07A has this (--- (7) and (----- (7A)
.....Box #09 Vehicle Ident Number 1G1AY078 BS
...............................................6E5100521
.....Box #10 Sched NO Date 01-0521
........................................12-16
I can't find anything that gives a date or time for my C4
Any further info that you can dig up is appreciated.
Thanks in advance
who has their 1984's Build sheet ..... What does it say in boxes #02 to #7A ( mine are all empty )​
...............................................6E5100521​
........................................12-16​
I can't find anything that gives a date or time for my C4​
Thanks in advance ! ! !​
Where is the build sheet on a 84 corvette?
What about an 85, same location?
I have no clue..... I have the RE-print from NCM, and there is alot of information missing I don't have a date or time of production
There is no build sheet on the gas tank, I looked
this is all the info i have on the top line from boxes 01 to 10
.....................................................(001290)
............................................. 6E5100521
What is listed in your box 10 right below box 1? My 84 reads 0007608 3-30 (march 30 1984) Eric
I believe your build sheet was printed on 12/16/1982. My late 84 has 3-30. The copy of the dealer invoice I ordered show it shipped on 4/3 so it lines up. My fed door sticker is 4/84 as well. What's your door sticker say? I bet 1/83. #521 is obviosly very early. Not sure how many pilots they made but I would imagine it was more than a normal model year. You should order the dealer invoice that will narrow down the ship date.
Eric
