MM-C5
- Joined
- Jun 30, 2003
- Messages
- 393
- Location
- 28.0 N x 82.77W
- Corvette
- 2013 Cyber Grey Grand Sport Coupe
Sometime ago, I tried to build a scale model of my 2000 C5 Coupe. All I was hoping to do was to get the color close but I simply do not have the talent. It ended up in the box in pieces for a couple of years.
Then I found Gary Mertens of Mustang OK who owns Built To Scale. So I shipped my "basket case" off to him for a "frame off restoration."
Again the only hope I had was getting it back with a decent paint job.
What came back is absolutely beautiful!
Gary primed and sanded the body three times before applying 5 coats of GM's Dark Bowling Green Metalic paint, followed by 8 coats of Clear Coat. He finished it off with a couple of applications of Meguiar's Gold wax.
His attention to detail is astonishing!
Not only did Gary get the engine bay trim correct, but he also did the "Brake Light Red" lettering on the front and rear facias, the red/black brake caliper scheme, and the C5 logos on the door sills. To top it off, he even has the door sticker on the driver's side door!
The only thing I could find that is wrong is that he set the radio to an Oklahoma Country Station...but hey, that's not all bad! :L
Gary reproduces memories!
Not only is the quality what you would expect from one of the big DieCast Collectible houses, it isn't one of thier selection that is similar...it is yours!
If you (or Santa) are thinking about one of these investments, I have to give Built To Scale 4
You may contact him direct: Contact Gary Mertens JMertens3@cox.net
You can view the finished model here.
Mine is a 1::18 die-cast.
Tom
Tom
