Bwmurph
Well, having been wrong on two counts now about what I blew up in the '59 - I thought it was the clutch; my mechanic thought is was the ring/pinion; it turns out it was neither - I've narrowed it down through process of elimination to - TA DAH ! - the Transmission. (Ther's not much else it could be, is there ?)
So, since it't not he original trans (it's a Muncie M20) I'm seriously considering going the 5 or 6 speed route; most likely 5 speed.
I guess the two big names out there are Keisler and Tremec. I'd like to hear from anyone who has installed either one of these trnamissions in either a C-1 or C-2 and what your opinions are on results and ease of installation. I really don't want to cut up the body (trans tunnel) if I don't have to. I don't have a high horse / high torque motor - it's an early crate motor rated at 300 HP and 370 Lb/ft of torque so I don't need a top of the line RS 600 or whatever is the equivalent Tremec is. Also, will I have to get a new driveshaft with the new trans or does it come with it ?
Any input / suggestions will be most appreciated,
Thanks,
Bernie O.
Thanks,
Bernie O.
