My 1966 had a aftermarket Mr. Gasket shifter installed.
I wanted to go back to original so I ordered the following from Paragon:
ITEM PART#
4 speed shifter - 1823
Bracket - 1930
Linkage Kit - 1918K
The problem is when the new shifter and levers are mounted, levers at neutral position, and the alignment pin for the shifter is in, the linkage rod adjustments have to be taken almost fully out (end of the linkage rod threads) to reach the lever holes.
I believe my problem lies in the fact that I purchased the wrong bracket. The bracket I purchased mounts to the trans crossmember and the years for it are L66-67
The bracket I think I need is 1828K, which covers the years 1964-E66.
I did notice that my crossmember is not drilled for one of the attaching screws for the late 66-67 bracket.
Has anyone done this before? It seems that the late bracket might actually move the shifter slightly to the rear causing the linkage rods to not be long enough, but this all seems strange.
Also, the levers contain two holes for the rod. Which one should be used? I can't tell in my assembly manual (upper or lower)?
Any thoughts would be greatly appreciated.
Doug
ITEM PART#
Bracket - 1930
Linkage Kit - 1918K
Doug
