If the axles are switched what would be the outward offside of one wheel?
Greetings Peter
Are you sure it's not to offset the weight compensating for the overweight driver?
TrueIf that was a concern, they would have put the steering box on the right too.![]()
Sorry, stupid me of course they are the same. On our dutch forum there is somebody with different length half shafts so i was thinking maybe he switched them. But as i had mine in my hands several times I should have known they are equalAre you sure it's not to offset the weight compensating for the overweight driver?
Sent from my SM-N920P using Tapatalk
I like brownies with walnuts.
Other than that, I got nothing....
Me too and me either!As there is only 3/8" clearance to the left side upper control arm with the engine offset 1-1/2" you can certainly understand why it had to be offset. And even with the 1-1/2" offset the big blocks BARELY fit.
So does that mean that the right sideAs there is only 3/8" clearance to the left side upper control arm with the engine offset 1-1/2" you can certainly understand why it had to be offset. And even with the 1-1/2" offset the big blocks BARELY fit.
