UKVETTEHEAD
Has anyone tried to fit Wilwood brake calipers to their C3. I understand that there is a set of bolt on calipers which are available but not sure if they would be worth fitting. My standard Delco Marine ones, with lip seals, tend to leak slightly if the car is not used for a while. Wilwood uses O rings which could be better. Any views would be appreciated. Thanks
