C4 1995 Dimensional Drawings
  • Thread starter Thread starter NickP
N
NickP
Hello, new guy here. I have a 95 C4 and am wanting to do some modifications/alterations. What I do not want to do is to have to tear it down just yet. My first area of interest is in the rear suspension. Mine is a D-44 centersection. Does anyone know of or have AutoCad files, drawings (dxf or dwg) or even a pdf of the parts, i.e. batwing, arms and other parts?
Your help is appreciated.
NickP
Welcome onto the boards there...
Best place to get exactly that is FSM, short of anybody scanning the info and uploading it.
Go to your local Chevy dealer, and they'll probably loan (or give) you the dusty copy off of the shelf.
If you are only after dimensions then any file to do with the C4 rear suspension will work.
All fixed components are the same 84 - 96
The knuckles /outer yokes/ brakes changed in '88 resulting in a wider overall width between the hubs.
The shocks were relocated to vertical mounting position
No dimensional changes were made to any other components; batwing / diffhead / chamber arms ( got a larger inner bush ) /strut rods /springs /etc.
These parts will interchange across all years
