96CEVette
Does anyone know what the California Emissions entails for the C4 LT4? What is different in terms of the mechanicals and impact on horsepower compared to the other states. Thanks for any thoughts.
The car had better have what it was made with, and it all had better work. If it don;t you fail and get tagged permantly on that vehicle as a "gross polluter" if you fail to comply and that tag will not go away. It means that if your car gets fixed you;re on your way, BUT, if you have to use a waiver, you are up against the state time frame for repairs and retesting.
You get tagged as a "Gross Polluter" only when your readings are way above the max allow limit by usually about 2-3 times. Gross Polluter status has nothing to do with a visual inspection and everything to do with your actually tailpipe readings. Every car has different allowable limits so there is no set number. There is a certain "wiggle" room between just failing above the limits and failing miserably as a "gross polluter" and requiring a Gold Shield station to pass. Once you fail miserably (way above the max limit) you can only retest and pass at a "Gold Shield" station for that particular smog. Here in Santa Barbara County before you would be permanently tagged and required to continue to smog only at "Gold Shield" stations from there on every 1 year instead of every 2 years even after you repaired the car and passed for as long as you owned it.
But now in Santa Barbara County at least once you repair and pass a Gross Polluter you can continue to smog at any non Gold Shield station of your choice biannually as you normally did before with no increase in fees.
For example. If your MAX HC was 120 and you come in at 150 you're not tagged as a Gross Polluter you simply just fail. Now if you came in at say 300 HC or higher then you're definately getting tagged as a Gross Polluter. The exact range of tolerance isn't given but based on the Gross Polluter vehicles I've seen and repaired to go on and pass it's about 2-3 times the max allowable limit
Here is when my non-vette daily driver failed as a "Gross Polluter" late last year. This was the first and only time it every failed in my 12 year ownership.
This is the SAME VEHICLE before and after my own repairs.:
Not bad for a car with 294K miles on the original motor. Clean as a whistle. So obviously I've been there and done that. Not only did I fix my own car above but I've repaired other people's Gross Polluters with similarly excessive readings just as successfully. Everything else I mentioned as far as smog rules I got directly from the Gold Shield station in which I passed the above vehicle at the time my passing certificate and keys where handed back to me.
Hi 86PACER, would you tell me what you did to achieve the remarkable turnaround? I'm having the same problem with my '88..Thanks....Roger.There is a 2% random selection for "test only" inspections aside from the other factors you mentioned.
There's some misinformation here about the California smog check.
There are three different types of smog checks required in CA.
Some counties, mainly rural areas, require a standard emissions test (run at idle and 2500 rpm with no load on the engine) only on transfer of registration.
Other counties, such as the aforementioned SBCo and others like it, require a biennial standard test.
Some counties, mainly in urban areas with air quality problems, such as the greater L.A. area, require the "enhanced" smog check which is an I/M 240 test. If your car is registered in an enhanced area, you get the biennial test and it's run on a chassis dyno at 15 and 25 mph. There is no random selection, ie: the majority of cars in enhanced areas must test this way. The only exceptions are a few vehicles which cannot be dyno'ed. In some cases, often cars CARB believes are high polluters but still legal, registered owners are ordered to go to "test-only" stations.
The statement that "the State" cannot force your car off the road is not necessarily true. If your car can't pass and cannot be repaired to pass and you don't qualify for any of the "low-income" exemptions (most of which are not open-ended) your only choices are scrap the vehicle or sell it out of state.
Don't think for an instant that the environmentalists who control both the executive and legislation branches of CA State government care about older vehicles. If they could force everyone (except certain low-income constituencies) to ride bikes they could.
People who own 2G ZR-1s already have a problem with NOx. What the State has been doing (quietly) is lowering the cut lines for certain standards (one being NOx) for older vehicles. This forces some cars which were previously legal to now flunk emissions tests even thought the engines are running properly and are in reasonable condition.
Persons in that situation are confronted with modifying the engine to pass the test (very expensive and perhaps not even legal), scrapping the vehicle or selling it out of state.
As long as an old car either is scrapped or crosses the state line going outbound and never comes back the CARB is happy.
Lastly, the State has tried twice in recent years to overturn the exemption for pre '74 cars and failed, however, with a new administration coming in run by Gov. Brown, an avowed hardcore enviro, and the legislature being as progressive as it ever has been, it's possible that bill might pass if anti-car legislators decide to introduce it. If they do attempt that again, it will be like the other two attempts and, if passed, will put 1966-74 vehicles back in the smog check.
Yes.. the hydrocarbon reading is 112 at 15mph and 86 at 25mph... that's right on maximum... My wife's Jaguar (6cyl.)..has just registered 80 and 61, against an allowable 80 and 45, everything else was wayyyy under. Is my Vette going to need to meet the same figures as the Jag, when it goes in next ? ....Thanks for your help.....Roger.......P.S...(My son served in Korea, Iraq and Afgahnistan in 'The 10th airborne').The smog readings?
Yes..
Leno can simply not register the cars that won't pass the smog check. He can still display them in the Big Dog Garage, he just can drive them on public roads. Actually, anyone can do that. I neglected to mention that non-operation is a third option along with scrappage and sale out of state.
Gray Davis was not impeached. He lost a recall election. Big difference.
As for Governor Brown (the only Governor-elect one addresses as "Governor") and the mandate he may feel he has...that combined with a legislature drunk on progressivism might just try to repeal the exemption. On the other hand, they also may end up with their hands full trying to deal with the State's fiscal dire straights and not have the time for such minutia...one can only hope.
Hi PACER86, The Jag had a new cat. fitted in '08, so it had to be pre OBD 2, but it's only done about 6,000 miles in 2 years. The Vette, I guess, may well need one, but I'll do some checking first. Thanks very much for your help......Roger.
