dhonick
New member
I can't get her started.
Checked the fuel pressure and get very inconsistant readings. It will go to 38 lbs in spec for a few seconds and then immediately drop right down to zero. Key off, key on - no pressure. key off key on pressure again and so forth. When I engage starter and turn motor, no pressure - zero. If there is pressure it drops off quickly. I have replaced the gas pump OEM, fuel filter, and fuel relay. VATS? Thank you in advance for any help ~ Danny
