XS650
Alex D said:besides, the manufacturer cannot (!) void your warranty if you use a non-API certified motor oil.
That's not what I said. I said
"That's all well and good, but by the original concern was about warranty compliance. If a person doesn't use oil that meets the manufaturers required specs, the part of the warranty that covers lubrication related failues is null and void."
Thay can't force you to use their oil unless they give it to you. That is commonly misundrstood to mean that you can use any oil your want to use, but that doesn't make it so.
If use oil that hasn't been certified to meet their specs, you are hanging out there. It then can become you responsibility to prove that the oil didn't cause the problem. The warranty is a contract, if you don't meet the terms of any contract, you put yourself in a weak bargaining position.
