c4 vert
messenger
il
1995 polo green conv
anyone ever used or currently using an item call sound killer ? It is supposed to buffer the noise between trunk area and passenger compartment as well as hiding the storage area.
Doesn't seem like you are getting many hits. Have you tried a search to help out?
There are a number of products that can be used to insulate and reduce sounds from the hatch - or cabin, if you line it too. Most are closed cell foam, and some are foil faced. Actually most work pretty good. Accoustimat or some similar name is the product I hear most about.
I have the sound Killer it does help. It is a little expensive and one could make one out of good quality carpet and some velcro.
Thanks you, yes it is expensive.I may try to make something out of foam and velcro
sound and heat...
Messenger,
You might want to check out a product called "Reflectix". I buy it at Home Depot in the insulation department. It's aluminum foil, bubble pack, aluminum foil sandwich and works dandy for heat insulation under carpeting.
I can't help but think it would work well to help with sound deadening as well.
hth,
Jim
