tvargo said:I need a recomendation on where to purchase a bra for a 2001 Mag Red C5.
Does any one recommend the GM issue?
Other suppliers?
Thanks,
Tom
Yes, in fact to put it on, the hood must be open. Take your time with the install, it seems impossible at first but it does work. If you have any problems just post here or CF and you'll get lots of help.tvargo said:One question: When the bra is on, can you open the hood?
Tom
Fly'n Brian said:Only girls should wear bras!!![]()
Iagreerwlc5 said:I have the GM issue for my 99. Fits very well and I have never had a problem with it. A much better deal for about $75.
[/QUOTE]Mine's definitely not a girl. I need a "Bro". I like the spandex ones that let the air flow through, but I don't know where to get one.Just my $.02 - skip the bra - any moisture will fade the paint if you don't get it off and air dry it pronto. Wife's Cyber Green metallic New Beetle had to be repainted, partially because of the bra.tvargo said:I need a recomendation on where to purchase a bra for a 2001 Mag Red C5.
Other suppliers?
Thanks,
Tom
I agree with some of this post but recommend the bra for occasional use on long trips. As long as you keep your car clean and waxed before you put the bra on, you should not have any issues. I do not recommend the bra for everday use unless you plan to clean it regularly and allow it to dry out after it gets wet. Otherwise, you are going to have the paint issues mentioned above.Moval49er said:Just my $.02 - skip the bra - any moisture will fade the paint if you don't get it off and air dry it pronto. Wife's Cyber Green metallic New Beetle had to be repainted, partially because of the bra.![]()
Zaino it up and hope for the best.
Lee
I can agree with that - wife just liked the looks of the bra and left it on too long... I use my Vette too much on Cali freeways to worry about it - it does have a couple small rock chips, but its still looking great after 2 years and 33,000 miles.jcs712 said:I agree with some of this post but recommend the bra for occasional use on long trips. As long as you keep your car clean and waxed before you put the bra on, you should not have any issues. I do not recommend the bra for everday use unless you plan to clean it regularly and allow it to dry out after it gets wet. Otherwise, you are going to have the paint issues mentioned above.
