Chick B.
Recently purchased my first Corvette. A C5, 1998 with only 6K miles on it.
We live in Central Illinois and my plan is to store my Corvette for the winter months. The vehicle will be stored indoors but not in a climate controlled environment. My question is, will the glass top be OK stored inside the car or should I consider storing it at home where it will not be exposed to the cold conditions?
I, also, plan to remove the negative battery cable. Is it better to connect a trickle charge? Should I remove the battery entirely? I had good luck with the trickle charge when I owned motorcycles, but not sure it would be a good idea with my Corvette.
I do have plans to get the car detailed this week and I plan to purchase a cover to prevent dust from settling on it.
Any other recommendations I should consider before I store my car? Please, advise.
In advance, thank you, for you help.
