I just got a international shipment from up north(Canada).
Here are a few pics of the New headlight system that will be going into my car.
There are DOT and SAE numbers on lenses so they are legal.
Stock light assembly is 1 lbs 14 oz each
T84 euro headlight assembly is 3.7 lbs each
New projection HID assembly is 3.05 lbs each
Retail is $1499
It is a complete plugnplay system.
This is what I got
2 new projection replacement housings
2 new phillips ballasts
2 H1s HID Bulbs with all wiring
2 9005 high beam bulbs
Complete Wiring harness with install instructions
3 year warranty on everything HID bulbs included!!!!!
The 9005 high beam bulbs are not covered. they can be bought at local auto parts store.
I am a supporting vendor they are having issues with my tag
CLICK HERE FOR LARGER PICS
INSTALL PIC'S AMD NIGHT PIC'S ARE ON LINK
After installing my set the dual harness isn't a bad idea,
It gives you the freedom to mount everything wherever you want.
Yes it is long on the drivers side so you have to cut and crimp it back together after making it shorter.
The ballasts have a long lead about 18 inches so custom hidden install would be easy.
I can make a custom harness for you if you like.
I mounted the ballasts under the headlights on front wheel-well.
Total Install time including mounting ballasts and modding harness is about 4 hours.
Remember to oil you adjusters.
Also do not over tighten the bolts that hold the headlight in place.
Retail is $1499
This is what I got
