I think they advertised that claim with 8 pounds of boost. I'll have to check tonight when I get home. I do agree though that much over 8 pounds of boost and you can look for the bottom end letting you know that you forgot about it
otfl. But we all know that aftermarket guys will tell you anything to get you to buy their produce......Right? The down side is that when S**t happens they suddenly disappear leaving you to fend for yourself. I guess that is the reason for the saying "You play. you pay".
I am still researching like crazy the pros and cons of SCing a stock motor. That very question was asked over on the corvette forums and so far it is about 50/50. The biggest con is the cost of purchasing a SC and the risk you take when you install it onto a stock motor. From what I gather is that if you SC a stock motor and keep the boost and tuning conservative, and don't keep your foot in it all of the time, then you can expect the engine to last a while. The other con is that on some units the manf recommends a rebuild of the head unit once a year. I don't know about you, but to pay 6 - 8 grand for an SC, go though the pain of putting it on the engine, and then a year later having to remove the thing and send it off for a rebuild would tend to spoil my party a little bit. The pros are the insane horse power increases and the boost is there when you want it.
An alternative to SCing is to Turbo Charge. I know that there are several companies working on TC kits for the vettes. That might be a better way to go if the price is resonable. But there are problems associated with the TC method of forced induction as well. On diesel engines when you TC you have to pay real close attention to EGTs or risk melting the pistons. I don't know if that is the case on gasoline engines. On my Dodge Cummins anything over 1200 degrees for 15 seconds can cause some serious engine problems quick. Also with high boost TCs you have to use piston coolers to help the pistons stay cool with the high combustion temps. But then again diesel does have high combustion temps. The other con is that boost doesn't come until the TC spools-up. So boost isn't available right now when you mash the go-pedal. The good thing about TCs is that the engine doesn't drive the unit (exhaust gases do) therefore there isn't any parasitic HP loss.
Hey Jack, i work up here in Boston. I try to get home once everyother month. The vette is tucked away for the winter at the house down in N.C. If the weather is nice during the winter i'll take it for a cruse down to the OBX. We will have to get togather next time I'm in Raleigh. Lunch sounds great. Haven't had any decent Carolina BBQ in a while. Are you going to go to Carlisle this year? If so maybe we can get togather and convoy down. There my be a couple of us convoying this year. Carlisle is a great time and great place to meet some of the other CACers.
Hey you guys keep the info coming about SCing. I still sitting on the fence.
H.D.
