corvette96
New member
I have 96 coupe with stock wheels. I want to upgrade to some c6 wheels that are 18x8.5 +56 front/tires P245/40zr18 and rears are 19x10 +79 tires P285/35zg. Question will they fit or will I need spacers. Thanks
I am using Z06 wheels on my 92 ZR-1. Fronts are fine as is. Rears are stock w 57mm offset while the ZR uses a 36mm. I have 18mm spacers BUT also using GM racing studs. They are longer and stronger. Make sure the spacer is BOTH hub and wheel centric. A good source for spacer/adapters is WheelAdapter.com is your number one source for wheel adapters, wheel spacers, used wheels, and wheel studs.. Very good quality and reasonable pricing.
