rkreigh
Hi guys,
since no one is building any Twin Turbo ZR1s anymore, I'm trying to get it done!!! I need help in selecting vendors and a technical approach. I have LOTS of turbo experience from my turbo buick days and have even hung around the callaway forums to learn as much as I can. I have been studying all the info I can get about the LPE, Mallett, and Callaway twin turbo ZR1s and even though this project WILL be expensive and a nightmare, I am determined and will raise the capital through some innovative business ventures.
please post here with any thoughts, here is the basis of my approach.
use stock 95 ZR1 manifolds with a "stub pipe" to mount two Buick GN turbos down low. I will probably use the stock "90 degree" knuckle and integral waste gate (ported) for ease of packaging. they are a bit restrictive, but power WILL NOT be much of an issue here.
use a walbro set of pumps and a dedicated oil tank/cooler to scavange the turbo oil, and keep any debris out of the LT5 in case of turbo failure.
mount the intercooler up front (spearco, twin inlet, single outlet) up front and fab a custom air box like LPE did. it keeps from having to relocate too much.
use a FAST computer to controll a MUCH larger secondary injector (83 lbs) with a wide band 02 sensor, retain the factory computer with a 220 cc injector for the primaries and a recal chip to lower WOT timing. I might consider having the just a custom chip made to eliminate the FAST, but I like the idea of the wide band 02 to help with fuel trim. Fast Lane went with an electromotive computer and a custom intake, but I would like to use the factory lt5 intake if possible.
use alchy injection to run pump gas and limit boost to 15 psi on the street, and use race gas at the track to turn up the wick. also considering some propane to help atomize the alchy with a fogger nozzle.
my budget for this project is about 35K. by using as much stock parts as possible, here's the breakdown so far.
368 (15K)
turbos, (less than 1500, way less if used)
intercooler (1500)
pipe bending/fabrication (8K) stainless ain't cheap
injectors (600, secondary 83 lbs)
FAST computer (2300)
tuning (2k, lots of dyno time)
fuel pump upgrades (400, two walbro 340s in place of stock ZR1 pumps).
walbro scavange pumps, plumbing (2k)
so far I'm up to 33,300 and NO labor (whew). now I see why the LPE TT cost 54K!!!
these are rough ball park prices, and obviously the labor will be another 10-15K so I have to economize a bit to meet my budget.
any and all thoughts are appreciated!!! thanks.
368 (15K)
intercooler (1500)
