camshaft failure
Hello
indianapolis
I have been reading and have been talking with some old timers at work and they told me about camshaft wiped lobed. Being with cadillac a light bulb went off in my head and i remembered guys installing camshafts in the 4100 for wiped cams. I have mu Uncles car with #8 pushrod intake broke. valve is stiff and knotty (sticks.) Should I just plan on installing a new camshaft and lifters. ;help
Are you referring to a cam that was recently installed? In any case, be sure that you follow proper break-in procedures for the initial start-up with the new camshaft and to use oil with a high zinc content.
I recommend you do a quick search on this topic as there are several threads that could give you helpful info.
Ralph
...#8 pushrod intake broke. valve is stiff and knotty (sticks.) Should I just plan on installing a new camshaft and lifters....
At the least you have to replace the broken pushrod and reset the valve lash on #8.
Might not be a bad idea to check the lash on all.
Sounds as though uncles car may ... repeat MAY ... may have a bent or galled valve. Of course, don't drive it until it's fully-repaired.
Regardless, an experienced knowledgable person should check cam lobes, lifters, pushrods, rockers, springs & valves.
If ... IF ... if it has a bent/galled valve ... simply replacing cam-lifters will hurt wallet ... and it'll be right back at square one ... or worse.
the only way to fix a bent/galled valve requires head remove-install.
next time, state year make & model ... that's lots more helpful than owner's identity.
Had to replace my 81 cam just short of 50K, because #3 lobe flatened out; on California vechicles, gas recovery is routed back to engine at #3 cylinder. Additional heat and a too soft (not hardened enough by factory) cam cause lobe to wear down, causing #3 cylinder valve to fail to open / function properly. Engine felt like it was missing; replaced plug, ignition wire, no improvement. Took it in, mech found the bad cam, replaced same, problem fixed. Mileage now around 130k, still running good, especially after rebuliding Carb.
