C
CAJUN C4
Go with the GM Hot Cam with 1:5 RR then you wouldn't have to change your springs I don't believe at .492 Lift?.
But you would anyway because they are 20 years old wouldn't you?Go with the GM Hot Cam with 1:5 RR then you wouldn't have to change your springs I don't believe at .492 Lift?.
I have found these brackets to be overkill anyway. I just eliminated them as there are still two remaining which leaves these accessories very secure.
A muffler shop should be able to supply the commonly used 18mm O2 sensor bung without having to cut up your original pipes.As for the O2 sensor I just cut out the bung from the original pipe using a cut off wheel mounted to a drill or air dremmel drilled a hole into the header collector and had the muffler shop weld it in place
