topless82vette
- Joined
- Nov 1, 2001
- Messages
- 910
- Location
- southern california
- Corvette
- 1982 convertible (not factory) stock 350cfi auto
My best friend is build up his 1990 corvette. The car has a six speed and I believe 3.33 gears. However this is what his motor will consist of. The mechanic who is doing everything says what he will have should only get him to low to mid 13's which I find hard to believe. but here is what his engine will be built like.
30 over 350
3.800 cola stroker crank
6.0 inch carillo rods
AFR 220 cc heads
cam not known
block machined for o-rings and splayed 4 bolt mains
8.0 to 1 compression
SLP runners (heavily ported)
TPIS big mouth base (also ported)
Ported stock plenum
58mm TB
42lb injectors
aftermarket ingition system
twin intercooled supercharger (P600B sounds familiar I think thats what he bought) Planned to be run at 12psi
TPIS long tube headers
TPIS 3 inch pre-cay pipe
TPIS 3.5 inch cat-back
flowmaster super44 mufflers
I believe his motor works out to a 394 stroker but not sure on that. Now does this combination sound capable of faster times then low to mid 13's? After all didn't LT-1 stock vettes manage that?
Whats your opinion on this build?
30 over 350
AFR 220 cc heads
cam not known
Ported stock plenum
58mm TB
42lb injectors
