topless82vette
- Joined
- Nov 1, 2001
- Messages
- 910
- Location
- southern california
- Corvette
- 1982 convertible (not factory) stock 350cfi auto
My best friend talked to his engine builder last night. So far his short block is complete. However he goes on to say this stroker will turn and make power to 8,000 rpm ...... I basically told him his engine builder has some much better drugs then anyone has ever seen or tried. But you be the judge. Here is the basics of this stroker it is I believe a 396 smallblock
block 30 over L-98
rods carillo 6 inch
crank cola 3.80
caps 4 bolt splayed
approx 8.0 to 1 compression
heads afr 215cc
cam unknown
TPIS base manifold
slp runners
58mm TB
PB600 twin intercooled ati procharger
tpis 1 3/4 headers
tpis 3 inch cat back
Now keep in mind this engine guy say this motor will pull this rpm and make power till then even though it will be using TPI.
I told my friend I dont even think a miniram would make power way up there .............
so will this engine make power up to 8k rpm and live as well?
block 30 over L-98
rods carillo 6 inch
crank cola 3.80
caps 4 bolt splayed
heads afr 215cc
cam unknown
TPIS base manifold
slp runners
58mm TB
tpis 1 3/4 headers
