Bolisk
I'm started my trailing arm rebuild project, and I've got everything disconnected except for the half-shaft and the forward pivot pin. I' went to take the half-shaft off the spindle. . .and I found that three of the four bolts are seized in place. My impact wrech isn't making a dent. . .and a breaker bar is not working either.
I soaked the three areas un PB Blaster last night. . .and I'm going to try to hit it with the impact wrench this evening. . .but I've never really had any success with any penetrating fluid. So. . .assuming this wont work. . .any other suggestions?
The only torch that I have is one of those gneric blue bottel torches that I use for plumming. If I heat the area up with that. . .do you think it will help? Or is that not hot enough? If I do heat it up. . .with that alter the metal's strengh. . .therefor preventing me from re-using parts?
I'm just a home DIY-er so please provide ideas that are do-able at the house.
Regards
Jon
Regards
Jon
